I have a funky lifter on the exhaust side on cylinder #4, If I replace the lifters and rockers do I need to do a cam break in sequence again?
74-76 motor, 8 heads. someone has been in it, it sounds like it has a small cam no lope really just a bit choppy said to be an RV cam lol, does not smoke that I can tell and has approx 130 psi across all cylinders. Was running so so with the Holley that came on it, so I switched to a know good summit carb and it ran better but still not right. Read the plugs after a few drives to work, they were lean but not glazed over. Pulled the intake, cleaned surfaces and replaced the tray, checked the timing chain back lash (very little). Set timing at 18-20 base. ported the vac advance it ran much better pulls about 15 inches at 900 rpms, still had funky valve train noise on #4. pulled the covers still had stock rocker setup on it yet and 4 was sloppy on both Int and ext, so I install a set of adjustable rollers rockers I had laying around for the other 350 build. The intake on #4 adjusted fine but the exhaust felt mushy at zero lash. turned motor over to build oil pressure up and readjusted exhaust and it felt good, did other cylinders on that bank and checked compression all good but 4 exhaust was mushy again.I would think the OG cam would handle it with some break-in lube or oil. VIN 9 is a roller, so no problem?
Been there done that, dont suggest it. I reopened the motor to replace all the lifters not much later and re break it in.I wonder if it would be possible to find an identical new lifter and replace the internals of the problem one (assuming just normal wear) on the base.
Do you know the lobe lift?Betting it is the 204/214 Edelbrock Performer cam or clone. My 76 350 had 140 to 142 psi with that cam.
Hopefully, not ground on a Ding How core.......Betting it is the 204/214 Edelbrock Performer cam or clone. My 76 350 had 140 to 142 psi with that cam.
