just got done putting duals on the car and the drivers side puts out less... i think its due to the gate gadget between the downpipe and the actual header. do i need this or can i take it out with no problems?
DRIVEN said:Are you talking about the heat riser below the exhaust manifold?
and yes i do have a 307, sorry guys i shouldve specified that.FE3X CLONE said:If he has the 307 Olds engine then the EFE valve is on the drivers side manifold between the exhaust manifold and crossover pipe.
Question is, what "duals" did you put on the car? The stock 442 style Cat-back system or actual true duals from the manifolds straight back? If you installed headers then there is likely no EFE valve there anyway.
