Longest engine has sat and turned over?
Monte sat for 10 years out in the open.
Put a new (used) gas tank in it with fresh gas.
Changed the oil filter and oil, stuck a garden hose in the radiator.
Jumped the battery and it started and ran it
Purred like a kitten and the 305 is now in my friends Blazer daily driver.
I got lucky!! :banana:
Reactions: Texas82GP
My car sat for 10 years in a parking lot at an old person commune in Pella, Iowa. P/O's son got it running. Drove it for a few hundred miles and it blew a headgasket and later that day the engine. Don't rely on a car that's been sitting on a daily driver. Think like this "can I push it home from here?".
the lt1 i put in my 66 wagon sat in my garage for 8 years, did't do a thing to it, just cranked it over with ign coil disconnected till i got oil pres and then fired it up.
bought a 63 falcon that sat in a garage for at least 15 years, changed oil and filter, drained fuel tank and refreshed with new fuel. again i cranked it over with ign coil disconnected till i got oil press, and fired it up.
my opinion is that the oil that is in it, was the same oil as before it sat. the bearing clearances haven't changed. get oil pres and start it.
joe
Reactions: pontiacgp
My tractor sat for 21 years in a leaky roof, open bay barn, and it cranked over with a new battery. The tractor engine was 55 years old at the time.
if the vehicle has an oil press gage and the gage works while cranking the eng, then i would crank it till you see the gage move. if it has a warning light, and the light operates while cranking the motor, i would crank it till the light goes out. if the first two suggestions don't work for you then i would crank it over in two 15 second segments. an industry rule of thumb is to not crank an eng for more than 15 seconds, to prevent starter motor from overheating. so with the ign coil electrically disconnected, crank it for 15 seconds, off for 15 seconds, crank for 15 seconds. hook up the ign coil and start it.
now I'm making a few assumptions, that the car has been stored indoors, the oil is not some ultra thick racing oil 20w50 and the ambient temp is not super cold. and the people you have doing this have done this before, or at least have a clue.
now if your people want to take the time, removing the plugs and adding a slight amount of oil would be great but could be more trouble then its worth. chevy motors have their plugs under the exh manifold, buick v6 and olds v8 engines are easier due to the angle of the plugs. but if too much oil is added, it could foul the plugs.
if you change the oil prior to starting the eng, fill the oil filter as best as you can before spinning it on the eng. less delay in priming the eng.
if using starting fluid, a little goes a long way. if you get a pop back, don't confuse this with a back fire, a pop back is on the intake side and involves flames out of the carb. if this happens, keep cranking, it will pull the flames down into the motor where they belong.
good luck
joe
Free running engine...pretty good.
So far so good for him too
