Looking for an uncoded trunk lock, where can I buy one?
7,989
18,697
does anyone actually re-key locks anymore ? We have 3x Fjords at work. Local locksmith ( probably 30 ) said they can't do it. His dad was great but passed a couple years ago and his son took over. Other locksmith said they can re-key the ignition to match the key but not the doors
Been broken in to a couple times so we have multiple keys for each vehicle now ( doors don't match ignition ).
At home I have 1 key for the house, shed, side and back door. Same at work I have it keyed same front and back doors. Would love to use 1 key to open doors and ignition on all 3 trucks
We run 2014-2016 Silverados at work. I've had several ignition and body locks replaced over the years. The little mechanic shop/gas station that does all our work is able to key the locks to the truck's key, or their lock smith is able to. I'd say you have the wrong guy working for you.
9,168
15,347
Since we are talking about locks.
Are the door lock cylinders the same as the trunk? Or is the trunk a one of a kind?
I personally never looked, so I do not know.
The lock cases are different between the door & trunk locks. During the usage og our style locks GM had a few different cases for both but most of the guts interchange.
78chevolds
126
50
The trunk lock cylinder is different. There is a slot in the cylinder that a small rod fits which then fits into the slot of the latch. I pulled the small rod out so I can get a flat blade screwdriver in the latch to open the trunk. I took the small rod out and noticed it has a curve to it. I am not sure if that is supposed to be that way, or it is bent. I had to take it to the locksmith and find out that it is bent. Again maybe it is supposed to be that shape. The F body trunk rod is longer and I don't recall it being bent.
