Well as it's getting close to Spring l started to get the shop in order, consist of moving vehicles out/around. I store important to me cars inside for the winter, an as we aren't euxpected to see snow again so l pulled the Camaro out but l need to pull the Escalade out first. So l pull it out, pull the Camaro out an l look over and see rust on the rockers, wasn't there last fall when l parked it, so being me l get a screw driver and start poking, yup there is a pin hole. Fuzz sakes!! An l thought l'd get back working on the Monty.
So l ordered a rocker guard because l knew the hole would only get worse when l really got at it. I had some Panel Bond from a couple years ago l never used because alittle nervous of it. I've always welded everything.
So l cut a 10" piece out to one of the seams on the rocker, don't understand why Cadillac put 4 seams in there Rocker Panel, put when you replace you have to buy a complete rocker. So l thought l'd use the Panel Bond on new rocker. l put on a flange top and one side of Rocker Panel, put a bead of Panel Bond on both flanges and bottom of rocker patch panel, stick it on an clamp, weld in the other side, and wipe away and extra panel bond, if you wipe it level your done. Well l wanted to leave a seam like the original on the one end so that end was just leave the excess Panel Bond. Now it's just work the one end that is welded.
No drilling for spot welds on the bottom of outer rocker to attach to inner rocker, no welding on one side nor the top. Welding all that takes time. Panel bond is proven(3M) to be stronger then rivets an tac or stitch welding. And it is water resistant.
So say you tack weld the bottom of the rocker panel, water can get in but with Panel Bond its a sealed seam that's water resistant. Seems like a solid reason to use.
Yes it's expensive, but so is a welder and Panel Bond is so very much faster, other than cure time, stronger and water resistant. I know GM truck boxes are put together with it. So if it's not a structural seam l think Panel Bond has its place in the DIY
area.
area.
