okgot '76 350 olds, stock with a rhodes 292 cam with .480 lift, q-jet and stock exhaust in a 86 cutlass, used to be a 'y' 307, its hard to start, have tryed moving timing and changing starter, when finally get it started and up to temp, when i get in the secondaries it blows gas out top of carb and makes a popping noise, won't run above about 3500rpm, didin't do anything to dist. but flywheights are a little worn, any ideas?
