Any ideas on picking some up?put them back in,it'll change the height.
Thanks looks like that is just what I need. And a lot less expensive than replacing my brand new springs.these go between the rear end and the spring they'll give you what you're looking for.
https://www.summitracing.com/parts/gls-1627/overview/
When I bought the springs the car was torn apart and before it sat really high in rear. After it’s back together it appears with the 2”umi shocks in rear that it is about 3/4 or 1” lower measuring from floor to the wheel well. I really don’t want to spend $200 more dollars for 1” drop springs just going over my options. I think I am going to get drop spindles for the front and lower it 2” now as plans have changed and the spindles became available today.if you put in new springs that were supposed to lower the car 2" and they didn't why are you not talking to the vendor
Yes springs the reason for not talking with them is because it’s not there fault I ordered wrong springs. They did what they were supposed to do. The springs that is.I think you mean UMI springs and not shocks. I must have missed why you won't talk to UMI. They are a sponsor here and are very helpful
No I only put rears on the car. I just recently had a deal come through for the drop spindles for the front so I will go that way.I thought you meant you bought 2" drop springs but the front only dropped an inch making the back 1" lower than the front. Did you not change all the springs?
