Buried deep in the old threads I beleive there was one about home brewed frame braces. This included frame rail end braces.Triangulating the rails where possible is best but just tying the frame rails together where possible is an improvement over stock.
That front set-up, connecting the link bar mounting points together, & the rear shock brace from UMI are worth adding.
Adding a brace @ the extreme rear of the rails is another opportunity that's overlooked.
I recalled seeing the information in a post/thread which is why I mentioned it. Not sure what thread though....Buried deep in the old threads I beleive there was one about home brewed frame braces. This included frame rail end braces.
My SS is all solid aluminum body mounts. Much stiffer..I did also use the aluminum body mounts from JT Raceshop. I haven’t driven the car yet so I don’t know how harsh they’ll be…
Beautiful!
Best option when cost is not a factor.For myself I have the UMI upper shock tower brace, upper and lower Hotchkis rear axle control arms, and an aftermarket 1/4 inch square tube t-mission crossmember.
Boxing the frame with the body still attached is possible but instead of going for a butt joint where the two edges, top and side, meet directly, you may have to trim the boxing strip so that it fits snugly inside the upper and lower rail panels and then indent it to get a 1/8th to a 1/4 inch of sill that you can use as a threshold or step for your passes. Remember to chamfer the insert panel(s) to get a wider surface to throw your passes at, it gives better penetration for more strength.
Absolute best option is to swap out the stock frame for a specialty iteration specifically built for the G-Body. Couple of the sponsors on this board are builders/suppliers.
