LS Grand Am Frame Strengthening Questions
tdvick
344
126
Elk River, Mn.
I did also use the aluminum body mounts from JT Raceshop. I haven’t driven the car yet so I don’t know how harsh they’ll be…
scoti
1,986
3,423
Texas
Triangulating the rails where possible is best but just tying the frame rails together where possible is an improvement over stock.
That front set-up, connecting the link bar mounting points together, & the rear shock brace from UMI are worth adding.
Adding a brace @ the extreme rear of the rails is another opportunity that's overlooked.
9,213
15,510
Buried deep in the old threads I beleive there was one about home brewed frame braces. This included frame rail end braces.
scoti
1,986
3,423
Texas
I recalled seeing the information in a post/thread which is why I mentioned it. Not sure what thread though....
Built6spdMCSS
5,839
9,766
Florida Beach
My SS is all solid aluminum body mounts. Much stiffer..
CopperNick
3,380
3,039
Canada
For myself I have the UMI upper shock tower brace, upper and lower Hotchkis rear axle control arms, and an aftermarket 1/4 inch square tube t-mission crossmember.
Boxing the frame with the body still attached is possible but instead of going for a butt joint where the two edges, top and side, meet directly, you may have to trim the boxing strip so that it fits snugly inside the upper and lower rail panels and then indent it to get a 1/8th to a 1/4 inch of sill that you can use as a threshold or step for your passes. Remember to chamfer the insert panel(s) to get a wider surface to throw your passes at, it gives better penetration for more strength.
Absolute best option is to swap out the stock frame for a specialty iteration specifically built for the G-Body. Couple of the sponsors on this board are builders/suppliers.
scoti
1,986
3,423
Texas
Best option when cost is not a factor.
UC645
1,088
3,090
Kittanning, Pa
I haven’t seen anyone using something like this, however I’ve only seen a brace setup like this on Trick Chassis’ website….
Not saying to throw ton of money at it, but if time is a factor and you’re unable to separate the body from the frame, a brace setup like that might be the best compromise. Exhaust fitment will be difficult however.
You could stand to stiffen the body a little if you throw poly body bushings at your car.
ASC worked out a rear seat brace for the GNX’s that Kirban reproduces:
If you’re handy with a welder, it’s far cheaper to make your own.
smed7880
132
171
Found rust in the left rear frame rail. Its body off now.
Will box while out. Not sure what else yet. Ordered the Hellwig 11104 G body kit.
Thanks for the input. its nice to ask rookie questions on a car forum and get intelligent replies.
