LS heads, cost for work.
Reactions: L67ss
Ah wasn't aware they used acid in hot tanking
It's not acid, its hot caustic. It will clean them, but it takes the protective oxide layer off of aluminum right after the dirt is removed. It can screw parts up in a hurry.
Aluminum doesn't corrode because it builds a protective layer of oxide. Hot caustic can corrode aluminum.
Iron doesn't have a protective layer of oxide. Oxide on iron is Rust. So hot caustic is used to clean iron.
Reactions: L67ss
