Randy_W said:Exactly, but in this case the LS is so much better and lighter that it can give up a few cubes, otherwise I agree and is pretty much what I said.CWPottenger said:I have been out of this thread mostly because it follows the same line as any other vs comparison. Unless you level the playing field the discussion is just an opinion piece.
To honestly compare a LS to an "oldschool"
1st must pick a similar displacement
2nd must pick a similar HP/Torque output
3rd must only use retail prices from same vendor ( one can always find that killer deal that other can't or have that friend that can do fab work for 6pack and pizza)
4th must have a common start point for platform (ie: same stock factory original vehicle)
5th must include EVERY piece, part, modification cost to make it a running driving vehicle .
Short of that there is no honest comparison. Personally I think both have pros and cons that make them both great and both poor depending on use, cost, complexity, ease of maintenance, appearance, etc.
And as for the SBC going 300k, some do, most don't . My current Vortec in my Tahoe has 167k and doesn't use a drop of oil or make any noise. But on a consistent bases the newer engines will outlast them and even the efi versions of the old engines will live far longer than carbed versions.
In my mind that's what it comes down too. Both engine platforms retain pros/cons over one another.
As for the newer engines outliving the older ones, i don't think so. I'm pretty sure its all how you take care of them, I've seen both old and new running with a pile of miles. Working at a garage I've seen some chevy trucks from the 90's to mid 2000s roll in with the high end of 200k, and one notable case was a 2000 something chevy/gmc, dont remember what engine but it had 307k, original engine. On the flip side, I've pulled 5.3's and others for top end problems at under/around 80-100k. It goes both ways.
Another good example, my family owns a 67 impala SS, 327(all orig except HEI dizzy, points had to go
