A
l am using a 2009 6.0 VVT Express van tune loaded on a factory E38 ECU. Any 6.0 or 6.2 harness would work with mods. The key is using a newer ECM that can manage VVT. The older red / blue connector ECMs won't work. If the harness does not have VVT, adding the 2 wires to the plug is not a big deal. Pin numbers are 44 and 52 on connector X2. Regarding the RPM switch idea, the older VVT phaser technology uses a fixed 2 position control (not variable) so it might work. I just haven't heard anyone doing it successfully. Personally I struggle with putting an old school carburetor on an modern engine and would make every effort to keep EFI. Later you will be glad you did. Many people do a carb and later upgrade to EFI. Beaterolds (Doug) is one of them.
If you haven't studied the harness layouts this is a good resource.
http://lt1swap.com/2010camaro.htm
Thanks Ill definitely look that over when I have to study it. I agree on efi being better for my application. I like it. In my case I was planning to just take my time, wait till I have everything i need and do the 6.0 with texas speed cam, efi, retain the AC, etc. My problem is Im starting to have issues with my small block and I have things I need to take care of at home. (like a new roof for one). I cant see spending to much time and effort on the small block having the 6.0 but I dont have everything I need yet.
At this time I need to make the swap as simple as possible. swap out the vvt, either sell it or save it for later, and intake and carb msd, Drop it in and continue to enjoy the car, take care of my house things, and Then I can continue to acquire the parts to do the efi the right way later on.
If I insist on Efi out of the gate, Itll just complicate things financially and time wise, Ill can end up with the car sitting for longer than I want it to.
