Could you fit 15" rims with the LS1 rear brakes?
Some 15" rims work. I had a set of 8" aluminum rims with drag radials on board and they fit. I couldn't tell you what rims work and what rims don't fit, but it certainly is possible.
Great write up! Thank you for creating/posting this, it is much better and a lot more clear than a lot of threads out there. Question for you - do you happen to know or measure the width of the final hub assy? I’ve got the parts to do this but waiting to buy AL hubs (personal preference, plus I want .5” studs). Will definitely be using this for reference when mine is done.
Tony_ru thanks for the CAD drawing.
Turned down diameter of the stock hub is 5.85". I bought a pair on ebay for my conversion.
I couldn't find the outer diameter of the Willwood hubs on their site but I also wonder that since their hubs are designed to be used with their rotor adapters, whether they work with LS1 rotors and calipers. Could be the thickness of the abutment bracket needed will be different.
I have seen this type of brake upgrade before and sadly I have heard of one downside. The stock hub is designed to be reinforced by the integral rotor, so cutting it off really weakens the stock hub casting due to the grain structure of the cast iron. This is why cracks are common with a hub with a cut off rotor. There are aftermarket rotorless hubs that are designed for such use but they are not cheap. Aonther issue is I think LS1 brakes require a 16 inch and larger rim. Stock 15 inch rims won't clear them which can be a problem for some of us.
I would be interested to see pix of these failed hubs. I have a hard time believing the hub with or without the rotor isn't up to the task of supporting its corner of the car no matter the situation.
This looks like an excellent way to upgrade on a budget.
This is the part that is not correct....So when the rotor is machined off, the loads and stresses are no longer displaced. They just build up inside the hub casting with its thin walls that now lack reinforcing.
The hub gains the reinforcing back when it's clamped together with the new separate rotor. Properly torqued lug nuts stretch the lugs which applies a constant tension that makes all the forces act upon the entire unit as if it were one single structure. This structure includes the hub, rotor and wheel.
