The opti spark system on the old LT1's are garbage at best and a pain to replace esp on a vette.
Rusty Nutz said:The opti spark system on the old LT1's are garbage at best and a pain to replace esp on a vette.
Fastmax32168 said:So much misinformation about LT1s is out there constantly spread about that it boggles my mind. I have a 94 Vette powered by an LT1 that makes near 500 HP, gets 20 MPG, runs bone reliable and has never had any issues at all with the opti spark. Nearly everything you need to build an LT1 is the exact same part you need to build a standard small block chevy. Cranks, Rods, Pistons, Rockers, Cams headers etc. So there is plenty of aftermarket support. Aftermarket Heads and manifolds are there as well, but the beauty of it is that they are not even needed. My motor is still running ported factory heads and intake. There is literally no part needed to upgrade an LT1 that is not available from multiple manufacturers and at a reasonable cost. Tuning software is available from multiple sources either cheap or free, and converting to a 4 barrel intake can be done for the computer impaired.
The LS1 is a great motor and has considerably more power potential than an LT1, but everything, and I mean everything is substantially more money for it once you start buying hard performance parts. Where this reputation that this is a cheap motor to build comes from I just dont know. You can get by inexpensively by swapping i
Anubis said:Rusty Nutz said:The opti spark system on the old LT1's are garbage at best and a pain to replace esp on a vette.
Yes, the early optispark set up was known for failure due to condensation and lack of appropriate venting but I've been running one of these on the LT1 in my truck for over 15 years with no issues. Far from garbage in my opinion. The early optispark modules can be modified for better venting if one chooses to do it for peace of mind. No need to spend the farm on aftermarket ignition systems......
jetsetw31 said:Fastmax32168 said:So much misinformation about LT1s is out there constantly spread about that it boggles my mind. I have a 94 Vette powered by an LT1 that makes near 500 HP, gets 20 MPG, runs bone reliable and has never had any issues at all with the opti spark. Nearly everything you need to build an LT1 is the exact same part you need to build a standard small block chevy. Cranks, Rods, Pistons, Rockers, Cams headers etc. So there is plenty of aftermarket support. Aftermarket Heads and manifolds are there as well, but the beauty of it is that they are not even needed. My motor is still running ported factory heads and intake. There is literally no part needed to upgrade an LT1 that is not available from multiple manufacturers and at a reasonable cost. Tuning software is available from multiple sources either cheap or free, and converting to a 4 barrel intake can be done for the computer impaired.
Yes a whole lot of misinformation. Even though your not having opti spark issues, It is a fact that the opti spark is problematic. I built a 580 horse LT1 on a 3 grand budget. The highest cost items were in the rotating assembly, the valve train, and the exhaust. (I ported the stock heads) Replaced the opti spark twice and went through 3 starters (one was a Vette starter and it cracked the housing!) due to failing opti sparks. The engine has a lot more in it but due to lack of High flow intakes, It wont reach the cam's rpm ceiling of 7500. It starts to fall off at about 6500. If I can find or convert a intake and ignition system to handle the rpms, it probably will be making close to 600 hp or higher.
550 hp from a LS1 can be attained with a little over 2 grand. So I've been told. I never built one to see if that's true. Yet... But i have checked out the prices for parts to get that HP and it's not impossible to do.
T
