LS1 vs. LT1
Agreed, Roy.
My apologies Kiddcutty, Seems I can't use an EXAMPLE of a race LT1 build showing a common, not overall problem.
Anyway, both of your choices have merit, But it's all about what your using it for. As I stated early in this post, the LT1 is cheaper and the LS1 has more power potential. This seems to be the overall direction of your answers.
Choose well. Kidd.
Well I went with the LT1 due to the fact that the doner car cost me $500 all it needed was a head gasket to run and the other the guy decided he wanted 3000gs for his wrecked 02 instead of 1g like he told me so screw that pretty much what I want with the engine is to have enough power to light up the tires and the usual red light races, occasional blast down the 1/4. ive done a lot of swaps but never a tbi or efi engine so to me this is new so ill be asking lots of help to you guys to get it in my car and maybe once its all done ill put the other turbo I have left from my experimental 260 that blew up for some reason hehe
also could I hook it up to my th350 transmission and my rear is a 8.5" will that be good it originally had the 7.5" but 1st owner of my car swapped it out im only the 2nd owner. what parts do I need from donor and what else could I take off an use
Basically, take everything from the donor. Especially the fuel system lines and computer harness. Also search this forum for "LT1/LT4 swap into monte carlo " thread. It has alot of info on what to do and where you can go to get even more info.
T
Yes, a TH350 will bolt up to an LT1 engine no problem but it isn't the best choice for a street car. I realize you already have the TH350 but a 2004R would be a better performance choice and you would get better fuel mileage. I helped a buddy swap an LT1 into an 83' G body Cutlass Supreme. He used a 700R4 trans and drive shaft from an 8.5" equipped Olds 442.
I would use the transmission out of the 95 Z28.
T
lets say I am really bad at wiring and don't know what or how to even by seeing can I just put a carb on it instead to make the swap easier with out the wiring
ok thanks and the th350 is basically for now and the 2004r still bolts up without using a kit and what is it a 3 or 4 speed would prefer 3 since my car has factory center console, t shifter
I'm not sure if the opti spark can run without the computer. I know that GMPP makes a dual plane for the LT1 but, It never crossed my mind to run a LT1 without FI.
I did find out that all you need is 7 things.
1. GM LT1 Carb intake- Part number 24502592.
2. MSD Bullet Distributor- Remove the oil valley distributer plug.
3. MSD 6AL box
4. Good Ignition Coil
5. Holley 750 Double Pumper, “Don’t **** with the Vacuumed secondary“ Or a Q jet for drivability.
6. Holley Blue Fuel pump
7. And a set of MSD 8.5 wires
You must keep the Lt1 timing cover all you need to do is plug the hole. None of the FI or opti spark wiring is necessary. Wires up like a standard chevy.
3. MSD 6AL box
would this also work for lets say a future LS swap
