LT1 Running Hot
What is the temperature the motor is running at? Most low emission engines are set run hot.
Every time I start my car up it runs not. I bleed the lines the way someone said to do on another forum. The outlet hose is hot, but the inlet hose is cool. Also, I have a gbody radiator.
One of the hoses being not the same temp as the other would certainly indicate that coolant is not circulating through the system. I just replaced a stuck thermostat on my car, because of the same symptoms. Engine getting hot quickly, and one of the hoses was totally cold.
Remember the LT1 takes a different thermostat than the "normal" small block chevy does
Reactions: Texas82GP
Water pump drive coupling installed?
Building any pressure on the hoses? No pressure (or very little) and pressure on only the inlet hose identify the issue - let us know.
