Water pump drive coupling installed?
Building any pressure on the hoses? No pressure (or very little) and pressure on only the inlet hose identify the issue - let us know.
A little history might help - just start happening, new build. Is it a reverse flow? Right water pump?
have you removed the rad cap to check the flow in the rad?
Don't look like its flowing, but if I leave the cap off when it starts to heat up the antifreeze comes out the radiator.
I measured the temp by looking at my cluster; which is a Dakota Digital VHX.Guys, ALL LT1 engines are reverse flow and there is no chance of buying the wrong pump for this engine. The water pump is unique to the LT1. How are you measuring the 220F overheat condition? I put a 96' Corvette crate LT1 into my Z71 truck and ran into a situation where the temp sender for the 96' was not correct for my 90' truck. I had to install the temp sensor that was calibrated to the gauge package. Not all GM sensors are calibrated to the same 0-5 volt scale. Which gauges are you using?
