Is there anything protecting that rubber line from chaffing? I would try to protect that hose. Hope i',m not coming off too critical of your work, just would hate to see it leak and possibly start a fire. Keep th pics coming!
jrm81bu said:Is there anything protecting that rubber line from chaffing? I would try to protect that hose. Hope i',m not coming off too critical of your work, just would hate to see it leak and possibly start a fire. Keep th pics coming!
350_85cutty said:looking good, hope the RTV caulking and plumbers putty works out for ya, i used some painters caulk on mine, bad idea, the heat from the engine makes it all gooey, shoulda known better, didn't even think about it. I used 3M undercoating on my heater box also, which i'll never use that stuff again, i used it on my frame and its not oil and gas resistant, stuff gets all gooey and wipes off when you go to clean it i had better luck with Dupli-color etch prime (the green stuff) then some dupli-color black spray paint, thats what i used to do my core support and frame the first time i swapped the 307 out, worked real good, took out the AC junk, you can see it in my build thread what i'm talking about, anyway, motor looks nice, I have a TCI sizzler 350 transmission and torque converter also, been wanting to get a set of those stage 8 header bolts. i did pretty much the same thing your doing not to long ago cleaning up the front end, getting it ready to drop the motor in
jrm81bu said:As long as you can get rid of all the edges touching the fuel line it should be ok. There could be some rubbing on the blunt areas but if its secured pretty good it would take a long time to cause a problem. Keep an eye on any problem areas once you start driving it and you will see any rub marks then.
