well guy's, where should I start. It's almost been a year sense I bought the car, and haven't drove her sense the day I brought her home. Sure, I use to switcher from side to side when I had her parked out side for street sweeping, but that soon changed when I came home one day to find that she had been side swiped. Man was I pissed!!!! Sense then, I have replaced the fender with one out of a 83 El Camino.
So long story short, she is still on stands. That’s soon to change!! With uncle SAM giving me back some $$ from taxes, I hope to have her on the road by summer!!!!!
At this point, I need to start hooking up most of the hoses under the hood (power steerng, rad hoses, heater core, etc) so I can start her up. Once that’s done, I want to focus on the suspension. I have actually been doing some research, and came to a conclusion as to what I want to do
The following are things I want to replace and install for the suspension;
all control/trailing arm bushings
Install beefier upper/lower trailing arms
Ball Joints
Install 2’’ drop spindles
Back/front springs
shocks
For the wheels, I’m going to be using a set of 16’’ irocs. At first, I thought of using some adapters, but after doing some research. I’m going to be replacing the wheel studs, and using spacers. I feel that it’s much safer, and don’t have to worry about having the adapter coming loose.
