good to know ill have to cut it outthe floor pan is the same in the 2 door, 4 door, wagon and el camino
do you know if the rad support/ inner front fenders/ rear window is the same as well?
As far as I know Malibu 2 and 4 door frames are the same.
Again, this is correct.
BUT, not all 2 doors are the same.
The difference is that the 4 doors and Malibu have the short stubby front frame rails.
It is very noticeable when you look at where the frame curves up to the front bumper shocks.
sh*t so that means the 4 door regal i just got has the stubby frame? good for a malibu but not a 2 door regal?
If G body frames were different then why are these frames advertised for all of the models expect the wagon
http://www.schwartzperformance.com/1978-1988-g-body-monte-carlo-chassis/
You shiuld be able to crawl under your car to compare the very front of the frame.
I "think" the malibu, lemans, grand lemans, Grand Am and 4 doors have the shorter frame, and either the Regal or Cutlass.
They must not realize Malibus have shorter front stubs. I can confirm this as my Monte Carlo front frame horns are longer than on the Malibu frame I have. They seem otherwise identical.
