Steve as far as that goes I have no preference, they work the same for their respective application. I do however prefer the '75 and up Q-jets, which I believe have the stepped rods you are asking about. The old and new rods have different lengths so are not interchangeable. I have used both series, pre-'75 and post '75, and I find the later models are somewhat more fine-tunable, what with the APT and all. They also accept the electric choke which I use exclusively. The pre- '73 models have a divorced choke that is useless without a matching intake manifold. I have not successfully mated an electric choke to those models yet. The pre-'72 models are usually equipped for the old performance minded motors and thus have better idle circuits that can better accommodate more radical camshafts. The post '75 models usually need the idle ports drilled out larger to get a decent idle with such cams.
