Best cfm mechanical fan you can get is GM 405442 although it is a 19"
I have electric fans on my Monte and some spares here for the Regal but I am still curious as to what temps you were running before and in what conditions and how much this 4 blade has improved cooling and also since this is mounted with a spacer instead of a clutch is it noisier since it does not free wheel?I can actually keep this thing cool now under all conditions..
Yes - still using the shroud, no reason to remove it. The Old school mechanical fan is the way to go for me since my car is just a basic Olds powered gbody.I assume that you're still using a fan shroud, correct?
I always thought running a multiblade clutch fan (7-blade in my case) was the ticket for an air conditioned car, but for those impressive temps, I may also consider going that route. However, I have no problems in the cooling dept.
Who would've known?
Another question for anyone that might know is will this rob horsepower at higher rpm's.
