monte stick shift
bausch2
n00b
Jul 19, 2012
2
1st time user I need help finding all parts to convert a 1984 monte to a stick shift with hydraulic clutch . I need pedals ,master and slave cyl.Also has anyone used a t5 behind a 454 ? I am going to have about 500 hp.
Thanks for the link but i beiive it is a bit dated and they are probably gone . Does anyone know if a manual linkage clutch pedal is the same as a hydraulic unit ? Thanks
That's a pretty lightweight transmission to put behind that motor. Look into Tremec for something that will take the stress.
if you don't plan on dropping the clutch too hard the T5 WC will hold out. You can also upgrade it with G force components. The trick with the G force is the gears are almost straight cut so it doesn't try to twist the aluminium housing
