Moog Control Arm Bushing ?'s
mguerci
Aug 30, 2006
56
8
Columbia, SC
I wanted to check the quantities needed to replace all the control arm bushings. I'm checking with the vendor, but I just want to see if anyone had any first hand experience.
Front
(1) K6411
(2) K6421
Rear Lower
(2) K6178
Also, does anyone know the Moog (or rubber equiv) number of the upper frame end bushings? I will be doing the axle end latter.
I did some further research, and it seems the bushings in the lower rear arms are the same as the frame end of the rear uppers. Does this seem correct?
hpe you have the skills to do this .....
it is quite a big job and dangerous at some point....
I changed all mine when i switched my coils ...quite a job!
at the back I went 4 links + panhard rod
Dan
