More body issues
Montecarlo79
Apr 23, 2025
72
55
16
image.jpgMore bondo found at both driver and passenger corner, not a shocker, should I put more on?
Putting more Bondo on that is like putting a Bandaid on a melanoma. It'll cover it up and make it look better, but the cancer underneath will still grow....
Depends on your end goal I guess.
Bondo absorbs moisture like a sponge and rots metal faster.
What’s left is thin metal covered in about 1/4” of bondo so does that mean that the original just rotted away so much that whoever “repaired it” put that much, I want to know what the original looks like so I can know if I need to weld in something new or just cover it?
the factory globed on seam sealer there i bet that is what you are seeing
Over 20yrs ago the floors on my 84 soaked went the car got wet. The factory sealer cracked allowing water in. I picked out all the old sealer and used silicon to seal it back up.
The best seam sealer is two part, 2k epoxy sealer. It's best to paint the area with 2 part epoxy primer, then seal with epoxy seam sealer, then recoat with more epoxy primer, then topcoat with 2 part urethane.
