If I would I would use less hardner so that it remained semi hard kind of gummieView attachment 255301More bondo found at both driver and passenger corner, not a shocker, should I put more on?
I picked at it more and it is gummie, I’ll try that just making it look neat and not crapIf I would I would use less hardner so that it remained semi hard kind of gummie
What’s left is thin metal covered in about 1/4” of bondo so does that mean that the original just rotted away so much that whoever “repaired it” put that much, I want to know what the original looks like so I can know if I need to weld in something new or just cover it?Bondo absorbs moisture like a sponge and rots metal faster.
Ok, I will strip it because it’s rusty, wire wheel it a bit and then out rust converter+seam sealerthe factory globed on seam sealer there i bet that is what you are seeing
