MSD Correct a Cap
pontiacgp
blank
Mar 31, 2006
29,270
20,425
Kitchener, Ontario
Have any of you ran one these caps?. It looks nice and stops the crossing of wires at the distributor...
that's for a vortec era motor, isn't it? If you have a standard HEI distributor, that won't work....
I don't know why it wouldn't work? Seems like the only way to go as there is little/no difference in price.
It is pretty but probably will not match integrity of OEM or Delco. If you like it and it looks cool on your ride
Go for it
Go for it
I have all msd ignition on my car and no complaints. The e curve distributor I have has an issue that the rev limiter has stopped working so that will go in for repairs this winter, delco is now made in china
I heard the quality of them isn't that good but I don't think they were using the MSD version
I think its worth using quality ignition components for sure. I would verify that that "crab style" cap does indeed correct the firing order like the Accel 8141R cap you linked. I thus far haven't read anything to indicate it does even though it "looks" like it does. You'll also have to buy new wires or re-terminate them depending on the style of cap you already have.
I have read a few forums about it, I think I'll pick one up to try it out before I put the car away for the winter....I have read reviews of the cap and no one says anything about having to change the wires but I see what you mean...
if you read this add at the bottom it says "Correct-a-cap type firing order"
https://www.msdperformance.com/products/distributors/distributor_accessories/parts/8017
and now I cam across a tune up kit which shows the wire ends and they are different than the hei ends...
I don't see any real benefit other than aesthetic. I've never had a problem remembering firing order or issues swapping caps or distributors.
