Muncie 4 speed in a 80 Malibu
What throughout bearing did you go with on your hydraulic set up?
Speedway it came with the shims a stop pin and easy instructions I used an4 line and put the bleeder outside the scatter shield another an4 runs up to a 3rd gen f-body hydraulic master with a conversion fitting I got on eBay but the rod on the master is to long for the g-body so I made a bracket on the back of the pedal for it
Reactions: Bar50
While I plan on beating mine...(not quite to rental levels*)
I want to be bench seat, four speed with an M21. I already have a reproduction Chevelle bench seat arm for a Hurst shifter.
A hydraulic clutch means I can use a scatter shield or normal bell housing.
This will allow me to use my 1 piece rear main 454 block.
Reactions: Clutch
My deciding factor was the Hooker headers for the olds big block I just had no room
Not any room with BBC headers either
