CUTLASS My 82 Cutlass Supreme
Before
After
Reactions: old80cs and Rktpwrd
Welcome from PNW
Very nice&clean,, does it have the 8.2 RearEnd ?
7.5 It's 99.9% factory stock.
In 1982, they had one rear end available for Cutlass. The 7.5". The 8.5" didn't come in G-bodies until 1984.
8.2 was used in applications through 1972. There was a 10 bolt and 12 bolt heavier duty version. IIRC, they got rid of the 12 bolt and made a "hybrid style" 8.5".
Simply look at the pumpkin of the rear end.
Check this thread:
If you don't have an idea of which rear your car came with look under the back. If you see pointy fangs at the bottom at the 5 and 7 o'clock positions on the housing, it's a 7.5. If you see triangles, it's an 8.5. Those are the only G-body choices you had from the factory.
Check this thread:
Check this thread:
Thanks for the info I will definitely get underneath and check it out.. It's so stock that I'm assuming from what you said it's probably the 7.5...
