The wagon saga continues.
Yesterday I got the two front tires on and put the car back on the ground. Had to move it around the garage on a set of dollys so I could get it out the door. Checked the oil. Topped off the TH350. Finally moved out under its own power. The first time since I took it apart to get it painted.
The motor sounded good on July 9th when I first got it running. I pulled out onto my street and drove it down to the end. Not a long run. Oil pressure was over 50lbs when I started it. When I got to the end of my road it was a lot less. It slowly started to drop as I was driving back to my house.
Coudnt tell if there were any new noises since the mid length headers are so dang loud. I was so pissed I pushed it into the garage with my wife and havent touched it.
Dont know if its the gauge, sender or oil pump. Filled the filter, primed the pump, Brad Penn oil. Pans full.
Im borrowing a mechanical gauge, pulling the HEI out and I'll spin up the pump to see if its bad. It wasnt a good day. SMDH
