my build up
Blake442
6,869
2,040
Minneapolis
Check your RPO label underneath your trunk lid. The rear end codes start with 'G'. Make sure to check the vin on the label matches the vin on your car.
Rear end codes for G-bodies:
GH2-2.29 ratio
GM8-2.56 ratio
GT4-3.73 ratio
GU1-2.41 ratio
GU2-2.73 ratio
GU4-3.08 ratio
GU5-3.23 ratio
G72-2.14 ratio
G80-limited slip differential
layedoutregal
154
Waukegan IL
thanks man..you know i thought i knew some stuff but i feel like i only scratched the surface until i came on here, you guys know your sh*t..thanks again
78mali350
1,689
5
38
Pratt, KS
GH2-2.29 ratio
GM8-2.56 ratio
GT4-3.73 ratio
GU1-2.41 ratio
GU2-2.73 ratio
GU4-3.08 ratio
GU5-3.23 ratio
G72-2.14 ratio
holy freakin helpful, I may just figure out what mine is tomorrow
Blake442
6,869
2,040
Minneapolis
Glad it helped, though I can't take all the credit for it...
http://gbodyforum.com/viewtopic.php?t=5155
The RPO labels are only on '84-'88 G-bodies... for '78-'83, you'll have to either be lucky enough to find your build sheet, if it's still intact, or order a vehicle invoice from GM for $50. I got one for my 442, as well as a restoration packet, that was full of info, including the codes for all the available options, and I was able to completely breakdown my RPO label.
http://www.gmmediaarchive.com/
Here's a great site to help decode the rest of your RPO label...
http://www.c2e.info/rpocodes/
layedoutregal
154
Waukegan IL
heavy d said:
nice ride.... I'm baggn my GN right now. If your bored on Saturday, the Midwest Turbo Buick get together is at Byron dragway. There should easily be 75 turbo regals there hanging out, racing, and just having fun....
http://www.turbobuick.com/forums/mid-we ... on-il.html
thats cool thanks for the invite, but were starting the frame work this week gotta get it done..cracked my damn frame twice..
layedoutregal
154
Waukegan IL
update so far!! cleaned frame only to realize the fracture in cross member is a bit longer, so for right now i put a reinforcement weld around the upper a arm mount and were doing the rest of the frame this week, need all new balljoints and complete steering linkages, car has never been maintained in like 15 yrs lol
layedoutregal
154
Waukegan IL
ok so far we fixed the crack, and painted the front part of the frame, pulled out the old rear end cleaned all the surface rust, replaced the brake lines on the axle putting on new shoes, cleaned all the old oil and resealed the pumpkin, found out it has Richmond gears 373..not bad for 300 bucks, oh and aluminum drums..will be installing in this week once i receive the bag mounts..damn feels like its never gonna get done..
