My Father's Oldsmobile
Yep, valve broke and took all kinds of sh*t out
Valve break or knock the keepers off?
side note- the rods appear to have not been the cause at from what I see. Unfortunately they’re looking like progressive damage?
Reactions: Turbo Zach
Yowzas.
So valve broke, rattled back into the intake and then bounced around the intake. Ish.
Are those Edelbrock valves?
The Edelbrock heads and valves are good quality. A stuck valve usually happens early on in the build, strange that it stuck after a good number of miles.
...................................yet the weak 455 Olds bottom end held up. 😏
No broken springs? Were you pretty tight on piston to valve clearance? I've seen the head snap off of a lot of valves at the stem, but I've never seen part of the head snap off before.
