Re: My Latest Carburetor (q-jet guys will get a kck out of t
I agree with you but for now I'd say just keep it as long as it seems to working properly and he's happy with it..
Clone TIE Pilot said:pontiacgp said:why junk it, Oldsmoletick said he's got it running properly now
Many of them do irreversible things to the carb castings. Such as drilling out the threads for the factory screw in valve seat and use a press in seat that are poor flowing and phrone to leaking. Heli-coil the main jet threads which also causes leaks. I already said they acid dip the castings as a cheap way to clean them but it really weakens and softens the pot metal alloy and can even make them porous enough to leak vacuum. They also drive plugs into the idle air bypass which can be very hard to remove without damaging the castings.
While it's good to hear Oldsmoletick has got it running okay, it probably still is not at it's best and never may be able to do it's best. Also the carb since once being reman may not last as long as an unmolested core.
