Well, here's the update on the motor. I was able to repair the timing cover the I gakked with the angle grinder when I had to cut one of the water pump bolts that had frozen itself in the block. I took it to work and drilled out the bolt stud that was rust-welded into the cover. It only took me about 2 minutes to drill through with the 3 phase drill press at work. I then used JB Weld to build up the gasket surface I destroyed with the angle grinder. I also used it to fill in 2 water pump bolt holes that had broken bolts in them that I had drilled out. It came out great and saved me $135 over buying a new one.
I also sandblasted and primed one of the valve covers. I plan on taking the intake manifold, the crank pulley, and the other valve cover to work soon to sandblast them as well.
Lastly, I removed the remains of the broken water pump bolt from the block and retapped the threads. Came out great!
Definitely small accomplishments, but bit by bit it'll get done!
