85 Cutlass Brougham said:
Thanks for the kind words! I wonder... what are your plans for the Eagle? Do you plan on keeping it stock under the hood, or maybe upgrading it? If you plan to upgrade it, consider using a Jeep 4.0 with the 258's crank. I think it gives you a 4.6 liter engine when it is done. VAM did a similar setup in the Lerma, which is a Mexican AMC Spirit. (VAM= Vehiculos Automores Mexicanos). Unlike the US Spirit, the Lerma was also available as a 4 door. Anyhow, if you need any technical advice on AMC's in general feel free to ask. I know quite a lot on the subject, even though I am giving up on them myself. I figure my next project needs to be something fundamentally different than the V8 rear drivers I have done up to now. AWD Turbo diesel Trabant, perhaps?
Thanks, as far as plans for the Eagle....I'm not sure yet, but fuel economy and reliability is what I'm shooting for on this car, first I have to finish wet sanding and buffing the car, then put it back together. I spent a couple months earlier this years getting the car to run and drive with the 258/4-speed set up (car had sat for 15 years). As for upgrading it, that all depends on how the 258 runs (seems to run excellent, but no road test yet), and also if I can teach my girlfriend to drive and
like standard (it is her car afterall). If all else fails, it will end up with a mpfi 4.0HO, AW4 trans, 242 transfer case, 3.55/8.25 rear end, which was my original plan anyway. I wasn't even going to mess with the 258, but I got curious, decided to see if it even ran, rebuilt the carb, gave it a tune up, and it runs near perfect. But, time will tell, if I do the upgrade, I'll get a whole cherokee to take apart, Ive seen people try to piece the swap together out of a junkyard parts, and only end in added expenses and frustration. If I take
everything out of one vehicle the swap should be much simpler. As far as a stroker.......that may be a rainy day project :lol:, that would be nice, since I already have the bottom end to do it.
