olds307 and 403 said:Your breather and pcv valve will be full, if it is an issue. It could also be unseated piston rings. My Olds 350 in my 4x4 is using oil and fouls two plugs after time. It needs a rebuild, pretty sure it has stuck oil rings. It has similar sludge.
offtopic but I would try changing the valve seals on those two cylinders
