Have you checked the valve lash?
7 times and had it done professionally once
That's going to cost you quite a chunk of change to have someone do your upgrade for you. I always buy the springs recommended for the cam. Unless you are a racer you won't be feeling the HP gain till your pushing RPMS. Put a good set of lifters in it and save a lot of money. One other thought - do you have to readjust valves around #7 ?? I believe you have push-in rocker studs, make sure your not pulling one.
If you want to do a roller by all means go for it and make sure camshaft end play is set. I have no problem on a used cam with new lifters AS LONG AS the lifters coming out show no signs of dishing and the cam ramp patterns look good plus you are low miles. I would install the lifters w/ asm lube and do a break in. I'm an old fart and have never lost a flat tappet cam and using a lot more spring pressure.
From the guy at the hot rod shop it was at, he says that only like 3 companies world wide are mKing these lifters anymore, no matter what the name on the box says. There like made by 12 years olds in third world countries who lost fingertips in the process. Also said the lifters and flat tappet cams aren't bullt like they used to be. The metals don't get the best curing and other processes like they used to. Says even with high Zinc oils and additives it's still not enough. People wipe cams all the time. That's the unfortunate disconnect between conventional car guy wisdom and multinational corporate cheapness.
Guess you found your engine advice !!
