If you have the big block frame pads then it should be simple. As stated I used v6 mounts. I positioned my motor to sit in the same spot as the the original sbc 305 and I only put the motor and trans in ONE time. The only problem I had was the buick motor is taller so I had to cut the middle bracing out of the hood to fit an air cleaner.
viewtopic.php?f=25&t=12117&start=30
