Turn signal work the right side brake light don't work and running lights on right side dimmerIf the turns work on both side in the rear the bulbs are good. sounds like the issue is in the turn signal switch. see print
Then issue is in the turn signal switch assembly, per the printTurn signal work the right side brake light don't work and running lights on right side dimmer
