i have roller prw 1.6 rockers with studs and hardened pushrods, its an olds 350 1970, the way he adjusted the rockers was while the motor was running he backed off the bolt on the stud till the rocker chattered then turned it till it stopped and did a qtr turn more and set the the set screw in the middle, ok so all was well from what i thought, i have a flat tapped cam and hydrolic lifters, mind you, so i assumed after break in u would have to adjust them one last time and be done with it, i looked on youtube and found someont explaneing how to do it so i figured id try, the first thing i noticed was when checked some of the pushrods there was some extremely loose before i released the set screw and the rocker screw, so i went thru the valvetrain doing them one by one and i noticed that on some when i would try to set the lash i was bottoming out on the stud?! i dont understand why, i ordered them from the guy who did the engine work, ( boring, port and polish), so i made another assumption and just went thru them all some was bottomed out and some werent, well when i dried to start the engine it turned over but wouldnt run, i didnt crank for more then 3 sec, i then took it apart and released all the pressure from the rockers and started to make sure i didnt bend a valve so it ran so i think im good on that part, but what could be my problem? lifters not holding psi?wrong studs, please help someone
