Need Help With Block Number
Carcray6262
40
Im have a hard time trying to identify what heads and what year this engine is #3955582 front of the block. there is a 59 stamped in the back by bellhouseing and there is a A6 stamped next to the head. other than that there are no more numbers. its a old 350 rocket im told.....came out of a 77-79 cutlass but doesn't seem to check out.. Want to double check before I buy it....Thanks for the help
Oldsmoletick
1,581
10
38
cny
That's a pre 77 block, can't tell ya anymore than that, what heads are on it? If it has #8's 73-76, 7A 72, 7's 71 (71&72, I could have these two backwards), 6's 70, 5's 68/69, (assuming it has its original heads). May narrow it down a little, not sure how to pinpoint an exact year. The number will be located next to the #1 and the #8 spark plug hole, you can't miss it.
Oregon350Cutlass
Jan 4, 2008
69
6
Carcray6262
40
According to 422.com it's 68-70 block. Which means that it would have num 5 heads if the engine has the original heads on it. Thanks for the links
jae
460
2
16
Do you have the casting numbers for the heads as well? There should be a six-digit number on top of the middle exhaust ports, and as Oldsmoletick said, a number at the front of the head (if looking at the driver's side head). That will tell you which heads you have, rated chamber size, valve size, etc...
Check the passenger-side head as well.
Oct 14, 2008
8,832
7,793
Melville,Saskatchewan
Head #'s should tell you the year, if they haven't been changed. The 68-76 used the same casting #'s.
Carcray6262
40
well i bought the engine today it has heads that have 5 stamped next to the 8th cylinder...asuming it has the num 5 heads on it....still trying to figure out which year cuz i need a couple bolts and gaskets...does anyone no if engine manifold bolts are the same with the olds 307 and old 350 same with the head bolts and valve cover bolts all help is well appricated due to this is the first time for a engine swap...thanks
Carcray6262
40
i need some help...i missing one of the head bolts and look at the price of them and i guess there over $100 for a whole set...where could i get just one bolt or will a head bolt off of a olds 307 work thanks
FE3X CLONE
2,714
51
48
Ohio
Most all the bolts are the same between the 307 and 350. However, if your 350 is a '76 or earlier block, then it has 7/16" head bolts. '77 and later Olds engines had 1/2" bolts.
Carcray6262
40
is there anyplace were i could just get one bolt because its all i need?....motor seems to be 68-70 according to the cast numbers and i has #5 heads....excited to put in but got a few thing to take car of before it goes in
