Thanks for your reply so fast it is a 307 distributor I put it in the 350 I just wanted to make sure it was safeasssuming you have a 307 the two engines use the same distributor but your 87 should have a computer controlled distributer
Yes, you can should be all fine. You could swap the tire computer system over to the 350 if you want, but you'll have virtually no adjustability at all. Might as well get a normal non computer 350 Olds thanks for your reply so fast I have to 72 motor in the 87 Cutlass now will I be able to advance the timing I was reading a couple other things online and people said they are good distributors they are HEI electronical and they do give a good consistent Spark I don't know how true that is I am new to all this motor swap
Thanks I don't want to sound stupid now when we have my friend did the motor swap because he knows a little bit more than me he didn't hook the computer harness back up but I know just the 1 harness that goes in the side of the distributor was hooked up now I don't know if that means it's running off the computer because the computer is not hooked up or that's just power I really appreciate your helpIf the distributor is directly computer controlled, the computer limits how effective your mods will be, but you can still upgrade the springs, weights, cap and rotor like a normal HEI. And the coil too.
