i actually didn’t i was looking at the progress and i seen she started leakingDid you pull the trans fluid dipstick tube out to pull the heater box? THAT maybe your actual leak. There is a rubber grommet on the bottom of the tube, if may have been damaged if you R&R'd it.
Armchair diagnosis at its finest...
thank you so much 👊🏽That's the Throttle Valve Sensor cable. No fluid in it. There is an O-ring in the bottom, that may have given up the ghost. If the cable had been installed right, there is a bracket that goes to one of the bellhousing bolts, so I am surprised the heater job is related. Could be it's been leaking a while.
To replace the O-ring, you have to pull the bolt out and disconnect the cable. There is a hook on the end of the cable...clamp the lever in the trans with a pair of needle-nose vice grips, but don't pull too hard or you'll damage the sensor. Swap the O-ring and reconnect it. If you let go you may not be able to dig it back out without dropping the pan.
You may need to reset the TVS cable when you are done. There is a D-shaped button in the end that hooks to the carb (two inches to the right of your pointer finger, on the other side of the metal bracket). Push it in, then pull the throttle level on the carb to WOT, then let the button go. If this is not set correctly, the trans may not shift right and you can damage it leaving it unadjusted.
is the throttle valve sensor same as throttle position sensor? anytime i look up a tvs cable or anything tvs nothing comes upThat's the Throttle Valve Sensor cable. No fluid in it. There is an O-ring in the bottom, that may have given up the ghost. If the cable had been installed right, there is a bracket that goes to one of the bellhousing bolts, so I am surprised the heater job is related. Could be it's been leaking a while.
I’m so sorry I never seen this reply! It’s the shorter 200r pan the 11 boltThe TVS is inside the transmission. TPS is part of a fuel injection system.
Maybe I should start over. Let's make sure I'm not giving you bad advice - we should decide what transmission you actually have there. What shape is the trans oil pan? Is there an electrical plug on the driver's side of transmission?
That doesn't make sense. If it's a 200-4R, then it has a TV (throttle valve) cable. Adjustment of that cable is ultra critical to transmission longevity. 200-4R's only came in 442 Cutlass's, Monte SS's and Buick GN's. Do you have any of the above newer than a 1984?I’m so sorry I never seen this reply! It’s the shorter 200r pan the 11 bolt
