Okay, not quite LS, but close enough. 02 3800 Series II won't stay running.
- I don't think it's VATS. Allegedly, ZZ Performance disabled that, plus the fuel pump relay is engaged until after the engine stops.
-With the vacuum line on the regulator, 40-42 psi... unhook the vacuum line and plug it, 50psi
- Throttle pedal doesn't do much, if anything
Kinda lost. Any suggestions considered...
