Hey everyone, I'm trying to mount my engine (97 lt1) and trans t56 to my frame so I can drill some holes to mount my trans crossmember to the frame extension that I made.
I'm using the holley clamshell motor mounts
And the umi engine mounts
First it was hard as hell to get the block mounted everything was off about a half Inch. But after some wd40 and a hammer it was attached. All the bolts where left loose during this ordeal. Finally attached the transmission set it down on the crossmember and snuged down all the motor mount bolts . And now everything looks like \ and the transmission mount is off by about a inch or so. If I loosen the driverside mount it straightened out.
