Neutral safety switch wire
buckola
24
Burlington ont.
Hi
I have a B&M shifter in my 79 El Camino and need to hook up the NS switch. I have hooked up the backup lites but cannot find the NSS wires(po has swapped in a different column) I don`t mind simply tapping in to an ignition switch wire I just have to know which one. pics would really be helpful.
Thanks in advance
Steve
david
20
fallon,nv
the wire you want is purple from the switch or a little farther down is the neutral safty switch either way the wire is purple
buckola
24
Burlington ont.
The purple wire it is!!! The only switch at the bottom of my column was for the Back Up lights. The column looks like it may have been swapped out by PO. However looping through the purple to the B&M micro switches did the trick.
Thanks for your help
Steve
406monte
Jan 24, 2009
57
6
Quantico, VA
The purple on i always wondered which one it was too. I need to hook it up also thanks.
