neutral safety switch
85ss/85gn
286
254
beaver dam,wi
What is everyone doing for the neutral safety switch for a t56 swap g-body?
81cutlass
4,649
13,565
Western MN
Either a high amp switch at the clutch pedal & route the 10 gauge starter solenoid purple wire that comes out of the fuse box back into the cabin, through the switch & out to the starter
OR a relay under the dash that just interrupts the purple wire & use 12V low amp wire to the relay to turn it on.
I don't have a clutch switch on my 2+2. I should, but no tech dept at a track has ever asked/cared.
oldsmobile joe
2,067
3,053
mpls
I added a factory clutch sw to my ssm clutch pedal and appropriate wire between ignition switch and purple starter wire.
