hey everyone, I've had a couple Grand prix', right now I've got an 84' Grand Prix with a 305cid chevy smallblock
-bored .30 over to a 310cid (3.766)
-stroke is the same as 350cid at 3.48
-Scat forged con rods with ARP bolts
-Fully balanced
-main caps strapped with grade 8 studs
-11.3:1 ratio with KB forged pistons
-ARP head stud kit
-1.6 compcam magnum roller tip rockers
-ARP screw in rocker studs
-compcam pushrod guide plates
-speedpro forged valves 1.94 intake and 1.50 exhuast
-full port/polish job on heads
-Compcam magnum 280h cam .512int/ext with the rockers (i want to go bigger!!)
-Edelbrock RPM Air-gap intake
-Edelbrock valve covers
-Edelbrock timing chain cover
-Edelbrock Victor series water pump
-Double roller timing chain
-Moroso fuel pump push rod
-Holly 110 gph fuel pump
-highflow oil pump with moroso oil pickup
-Moroso deep sump oil pan (takes 8.5 litres of oil)
-ARP bolt kit
-Holly 600cfm four barrel street\strip ( i need to go with a 650cfm because im getting more gas then air)
-B&M flywheel
-high performance starter
-MSD Street Pro-Billet distributor
-MSD Blaster SS Coil
-MSD Ignition Box, MSD 6A
-K&N X-Stream Air Flow
-100amp chrome Alternator
-Flowtech headers (worst headers in the world)
-new Motor Mounts
-Eaton posi
-4:10 gear ratio
-Moser axle's
http://www.cardomain.com/ride/768013
-Fully balanced
-ARP head stud kit
-ARP bolt kit
-B&M flywheel
-new Motor Mounts
-Eaton posi
-4:10 gear ratio
-Moser axle's
