Just got a '79 LeMans project and had a few topic related questions while I'm in the planning stages. I've browsed through the board and got some ideas already, hopefully you guys can bear with me in case this post gets long. The car currently has a 267 V8 with a 3 spd auto (assuming it's a TH200?), I haven't gotten around to checking the rear end codes but I'm guessing it's a 7.5" non posi rear. A friend of mine's dad has a factory 300hp 350 V8 and a TH400 out of a '69 Chev wagon that I'm getting for free so that's what I plan on swapping in. My goal is to have around 325-350hp when I'm done and I have a few questions about this swap and what else I'll need to make it happen.
1) I want to get an 8.5" posi rear with 3.73 or 3.42 gears. I know that Monte Carlo SS, 442, and GN's would probably have something like that but are there any other donor cars I could be looking at that would have the same rear end without having to modify mounting points, etc.? I want something I can bolt right in. I used to have an '81 Z28 that was up around 300hp that had an 8.5" posi with 3:42 gears and had no problems so I'm guessing strength won't be an issue?
2) Will the TH400 bolt in wihout too many mods? I figure I'll have to do something with the rear mount but what about linkage? I'm also assuming I'll be needing a new driveshaft due to length or # of splines compared to the stock one?
3) How much of a pain would it be to change it from column shift to floor shift? Obviously I'll need to cut the floor, but would the linkage be an issue? It's a full bench seat now but I'd like to switch to buckets and console with a floor shift. My guess would be that I could use a lot of parts from a GP (linkage, console, seats, etc.) but I'm not sure.
I was lucky enough with my Z28 that I never had to swap transmission types or rear end because what it had was fine. The engine rebuild I'm comfortable with but I don't have a lot of experience in parts swapping like this so any advice would be appreciated. Thanks.
