New/old member
I will be running a pair of Garrett Turbos for my car and one of them will be their new mirror image so I can go for that symmetrical look 😉 My Coyote will be stock 302 displacement to keep the wall thickness up.
As far as the LSX, it will be 427CI with a pair of Garrett turbos on it. I'll have to post pics of what we've done for him so far, I think you'll like it!
302cu.in.- 1600hp, that's just amazing when you think about it. Modern day hot rodding is definitely badass.
I think I heard something about the Coyote being pretty high revving? How tight are you gonna wind that new age 5.0?
I just did a quick read up on the Coyote and as bad as it kills my Chevy loving soul to say it, I'm impressed. That's a pretty badass little engine.
Have you had any experience with the new LT1? I think that would be a cool swap for a G Body and it would keep it all GM. 😀
Oh boy the next trend is starting lol
Almost, lol. I had a customer that was going to have me do a new style LT1 & 6 speed swap into his 1978 Corvette then he found out that the new drivetrain was worth more than the car so he decided to pass and is now hunting down a "deal" for an LS & 4L60 trans.
As far as how high I'm going to rev mine, I'm thinking between 8-8500 as I'm sure it'll still be making plenty of power below that range 😉
Reactions: Opie Knievel
You got some welding to do on a G-BODY lol that's going to be sick I like it
Reactions: Andebe
LOL, I wouldn't mind be a trendsetter. I will admit that I wasn't a fan of the 4 valve overhead stuff at first as it seems a bit overwhelming and complicated but once you get into it it's not bad at all. What impresses me the most is the power & drivability that can be had out of these little engines. The VVT really shines with the drivability characteristics and even when it bypassed they still run & drive great. The other big thing that I like with these engines is the very minimal head gasket & sealing issues that they have. I've worked on a lot of the 2013 & 2014 Shelby GT500's and a ton of Coyote engines and have yet to see one fail (personally). I feel it has a lot to do with the valves being overhead and not have all of the pushrod & spring pressures constantly wanting to lift the heads off the engine before you even add boost.
How so or what for? Meaning for a frame notch and cage?
BTW, will a 315/60-15 fit reasonably well with just a frame notch? It's been a while since I've worked on this platform and forgot 🙁
If you check out some builds on here a lot of guys are boxing the rails and adding braces to stop them from flexing so they leave straight also so they don't rip out trailing arms you'll see
Ok, I follow you now. I remember seeing years ago guys doing extra supports and bracing between the rear frame rails, especially once notched. Fortunately I've got a 2 & 4 post lifts so I figured I'd be lifting the body off at some point to add bracing and supports. I'm familiar with reinforcing the "torque boxes" from the Foxbody stuff. I'll also be doing an aftermarket vintage air so I'll be able to get rid of the big ugly factory air box and free up some engine bay space.
What about fitting the 315's, any issues with just a frame notch?
I'm not sure I do know I had 29.5-9-15 slicks on my 87 olds with 1/2 spacer on olds rally wheels and they hit the inner wheelhouse in front of the tire and cleared the frame with no notch
that's the biggest tire I ever tried to use on a G-BODY
